smokerise411
Feb 13, 2021Aspirant
AC1750 R6400 Ruko streaming buffering constantly
I have a Ruko TV that I can not watch because it buffers constantly. My provider says it my router. And of course Netgear wants my to pay for 6 months of support to help me fix it. I am not a computer person so all this is greek to me. Is there a simple answer?
What roku tv model is it?
How far from the router are you and whats in the all (wall/objects/what are they made of?)
Are you trying to stream over 2.4ghz or 5ghz?
- smokerise411Aspirant
Ruko model NS-24DR220NA18 - TV and netgear router are in the same room. No walls. Appprox. 12 ft apart
I couldn't find if that tv is single or dual band.
If its single band, try hardwiring in the tv. If its dual, make sure you're on the 5ghz.
How fast is your Internet?
I use Powerline Ethernet to connect devices that don't move around the place. Easier to set up and more reliable than wifi. But that too is limited by the speed of the Internet connection.
This place is free.
