javierHD's avatar
javierHD
AC1900 intermittent and slow speed
Nighthawk AC 1900 Smart WIFI Router Model R7000 purchased on or about Nov 2019. Currently on version V1.0.11.122_10.2.100
For several months now dropping internet connection (not dropping the Wifi) and, not at all providing the speed supported by the ISP which is about 200Mbps.
In 2020 I was getting speeds of 200Mbps, and now I get at most 30-50 Mbps, wired or wireless the problems shows up.
Called customer support on early 2021 and they advised to replace the switch and also to buy a mesh extender.  All this for nothing. Waste of money.
Called cutomer support again and they told me that I am out of warranty.  Not sure why Netgear puts this bug on the device as opposed to the Firmware upgrade.  This is a problem shown on threads at least since 2018.
Customer support advised to downgrade to R7000-V1.0.11.106_10.2.100 which I did and within a day, problem is back.
I have tried many of the advise on this forum (thanks for all the attempts)  and just nothing works for me.  Now I decided last for a hard reset after upgrading to the latest version V1.0.11.122_10.2.100 only to find out the device will not respond to the hard reset.  The hard reset also not possible on version 1.0.11.106 so I went all the way to R7000-V1.0.9.42_10.2.44 for the hard reset to work.  I have also tried enabling and disabling of QoS, currently disabled, that did not work with or without reset and update of database.
Now what shall I do?  The amount of feedback provided on this device and no support for such an expensive device is not appreciated.
I hope Netgear sees this post and responds with a reliable solution.
any help would be appreciated...TIA
  • Here's a set of rules that helped me get my R7000 healthy:
    Factory reset and hard reset are the same thing.  Can be done either way:
    • Paper clip press for 8 to 10 seconds until all lights go out and then release
    • Log into the router, go to ADVANCED > Administration > Backup Settings and click Erase.
    Factory reset only clears configuration settings.  It does not bring back the original FW.
    • The router only holds one FW version at a time.  There is no ROM to store original FW.
    It's a good idea to perform a factory reset before and after installing FW.
    • Reset before installing FW ensures minimal configuration incompatibility
    • Reset before installing FW maximizes the odds of a successful install without bricking the router
    • Reset after installing FW ensures that old, incompatible configuration settings are wiped out.
    Do not restore configuration from a file, because the file is tied to the FW version that generated it.
    • You must re-enter all your configuration settings by hand.
    My R7000 has been on '116 for 3 months and it's been working well.
    • javierHD's avatar
      javierHD
      Bill-D The ony thing I did not perform was erase the Backup Settings.  Thank you for the recommendation, will come back w an update...
    • javierHD's avatar
      javierHD
      Bill-D Thank you for the advise but unfortunately no change.  Worked for about a week and then started all over again.  Today dropped my internet connection 4 times, and at least 1 time every day if not otherwise poor wifi speeds.
      I guess the solution is get a new router, not by NetGear this time.
  • Any recommendations on use of Smart Connect
    Also, any recommendations for Channels?
    Thanks
    • Bill-D's avatar
      Bill-D
      Apprentice
      I've always had my Smart Connect unchecked and I've always used different SSID names for my 2.4 and 5Ghz networks.
      I have my Channels both on Auto.  I also have always had my Implicit BEAMFORMING and AIRTIME FAIRNESS unchecked.
