Orbi WiFi 7 RBE973
Reply
Are the the ethernet port lights supposed to be red when connected?
Aaron65
I have my pc connected through ethernet cable is the port light supposed to be red? The rest of the lights are white.
Message 1 of 2
Accepted Solutions
TheEther
Guru
Re: Are the the ethernet port lights supposed to be red when connected?
The color of the light indicates the connection speed.  White represents Gigabit and amber represents either 10 Mbps or 100 Mbps.
If your PC has a Gigabit Ethernet port, then you should verify that it's set to Gigabit mode.  Else, check your Ethernet cable or try a different router port.
I've had a Ethernet cable that would only connect at 100 Mbps.
Message 2 of 2
All Replies
TheEther
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 21153 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
