empf1969's avatar
empf1969
Follower
Feb 23, 2021
BR200 - BR500 Insight Instant VPN Router
Hello to you,
I tried consumer VPN Routers and have been disappointed. I am wondering if you could confirm whether or not BR200 or BR500 Insight Instant VPN Router can be used for home users to connect to VPN providers using for example Open VPN for please?
Basically I have a VPN provider similar to NordVPN and been using a Asus Router and although they are nice to look at, those routers are rather bad at encrypting the data for the lack of powerfull processors (CPU)
The consumer range of VPN Router focus more on the Wifi as opposed to creating powerful VPN Routers to achieve high speeds, which makes me feel disappointed.
Could both BR200 - BR500 Insight Instant VPN Router be used as a home as a VPN Router using Open VPN and if indeed I can use either ones which modem is best suited for me please,
Many thanks
EMP1969
1 Reply
ProSupport for Business
