Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best CFW for R7000 with Hardware NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-10-23
06:06 AM
2016-10-23
06:06 AM
I have a Nighthawk R7000 and have recently started looking for custom firmwares for it, basically for different Vlans on the Lan. I tried
Kong's WRT- My 1G internet link couldn't exceed 500Mbps, no matter what. On further research, turns out this firmware doesn't support hardware NAT. CPU was at 100% at 500M, and at 90 degrees C. Also, 5Ghz didn't go above 150mbps even 5 feet from the router.
Tomato by Shiby-this doesn't seem to have the NAT CPU issue, but my 5Ghz performance was significantly lower than stock. My Windows devices generally connect above 800mbps at my study table, but with this didn't cross 200mbps. I tried toggling and playing with different settings, to no avail (same channel as stock). I saw there was no mention of beamforming, could that be the reason?
Are there any other firmwares I can try which do NAT in hardware and support beamforming?
Solved! Go to Solution.
Message 1 of 5
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-10-23
06:21 AM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-10-23
06:21 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-10-23
06:27 AM
2016-10-23
06:27 AM
Re: Best CFW for R7000 with Hardware NAT
Thanks, but that is not an optimal solution. It wouldn't let me utilize my ISP's full bandwidth for one.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-10-23
06:32 AM
2016-10-23
06:32 AM
If you don't like the Xvortex firmware (link I posted in first response), consider purchasing a Ubiquity ERX (it does everything you want to do) and configure your R7000 as an Access Point, with latest stock firmware
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-10-23
06:35 AM
2016-10-23
06:35 AM
Thanks. I will give that firmware a try. I will get the fans you recommended anyways.
Message 5 of 5
Announcements
