keithamason's avatar
Jun 23, 2021
Bridge Mode on AC1600 Model R6330
I'm trying to configure the AC1600 Model R6330 for bridge mode.  The manual indicates you go to ADVNACED > Advanced Setup > Rounter/AP/Bridge Mode.  However this is NO "Rounter/AP/Bridge Mode".
The manual doesn't have ANY screen shots, so I'm stuck.
  • plemans's avatar
    Jun 24, 2021
    On the page you linked to, click on "use other operation mode" then "enable bridge mode"
  • > [...] R6330 [...]
    > Model: R6300|Dual Band 11ac WiFi Router R6300
       Which is it?  Firmware version?
    > [...] The manual indicates you go to ADVNACED > Advanced Setup >
       What _did_ you find there?
    > The manual doesn't have ANY screen shots, [...]
       Neither does your complaint.
       Are you looking at ADVANCED > Setup or ADVANCED > Advanced Setup ?
    • keithamason's avatar
      keithamason
      Guide
      Version: V1.1.0.78_1.0.1
      See attached image for the configuration screen
      • plemans's avatar
