Qwerty111's avatar
Qwerty111
Follower
May 05, 2017
Can't connect wireless Brother printer to NETGEAR router AC1750 model R6700
I'd say I'm about a day or two away (max) from simply returning the new Netgear Modem and Netgear Router I bought to replace the one I was renting from Xfinity, and which worked perfectly well.  As far as I can determine, I followed all directions re connecting my wireless Brother printer HL-L2369DW, but I have failed. And my tech-savvy teenage son was also unable to connect the printer.  I am so *$&%^#@)-ing frustrated I cannot begin to explain.  Can someone give me clear, step-by-step instruction how to connect the printer?  Thank you.
  • Welcome to the community, Qwerty111
    Is it correct to assume that the printer is connecting wirelessly to the router?
    Do you have a computer that can get online wirelessly?
    Are there any other devices that can get online through the router?
    If the printer is connecting wirelessly, all you have to do is to make sure that you have the correct wireless settings to input into the printer.
    Verify the wireless network name and input the correct wireless password.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
  • JamesGL's avatar
    JamesGL
    Hi Qwerty111,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
