Bosse1's avatar
Bosse1
Cannot not stream Netflix and Hulu through switch GS116v2
The network(wired) setup is cable modem CM1200 (Firmware V1.02.02 a newer version is available but ISP GRANDE say they don't have or don't update firmware). Wifi Router RAX80 (Firmware version V1.0.3.102) is connected to the cable modem and Switch GS116v2 is connected to RAX80.
When turning on either one of the four LG TV's and iniating for example Netflix it wan't load up just ERROR and the same goes for all other services we have.
After this I reverted back to old modem Arris DG2470A and connected the switch to it and streaming is restored throughout the house.
I also tried to connect the switch to the modem but the result is the same.
If anybody out there has a clue what is going on, please let me know.
Thanks,
  • plemans's avatar
    A couple things.
    1. the Arris DG2470A is a modem/router combo device.
    2. The CM1200 has 4x ethernet ports but only port 1 can be used for that vast majority of isps. Make sure nothing else is connected to it. other than the router.
    3. If you directly connect the RAX to the tv. does it stream? (skipping the switch)
    4. Do they stream/work over wifi?
    • Bosse1's avatar
      Bosse1
      Hi GURU,
      answers to your questions;
      1. Yes, DG2470A is a modem/router combo.
      2. Yes only the RAX80 is connected to the top port.
      3. Direct connection RAX80 to TV doesn't work either.
      4. Yes, TV's streams over wifi.
      Regards Bosse1
      • plemans's avatar
        No other devices have issues?
        Just the one TV?
        And other devices can use the same ethernet port without issues?
        Was it somehow blocked through access control?
        Have you tried a factory reset and clean reinstall (not from backup) on the RAX?
