cleveland35's avatar
cleveland35
Connect wireless laptop to ethernet printer
I have an HP Officejet 6700 connected with an ethernet cord to my network.  Printing is fine from a desktop or laptop when using a wired connection to the router.  When I use the laptop in "wireless" mode, I cannot see the printer.  How do I let the wireless laptop print to the ethernet connected printer?  Thanks!
  • antinode's avatar
    antinode
    Aug 06, 2020
    > I had already updated the firmware [...]
       How could I have not known that?
    > I don't know what "Did you use Address Reservation on the router to
    > ensure that that's always true?" means. [...]
       If the IP address of the printer changes, then your computer might
    not be able to find it where it was expected to be.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Manage
    Reserved LAN IP Addresses".  If you reserve an address for your printer,
    then it should always get the same address, which might help in a
    situation where it had been wandering.  No guarantee, but it's an easy
    (and generally harmless) experiment to run.
  • > Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
       Is that accurate?  Firmware version?  Connected to what?
    > [...] When I use the laptop [...]
       Not a very detailed description of that device.  Windows?  Other?
    > [...] in "wireless" mode, I cannot see the printer. [...]
       How, exactly, are you trying to "see the printer"?  Unless you're
    using a "guest network" for your wireless connection, it should just
    work.  If not, then bad firmware would be my first guess at a reason.
       Does everyone appear in an Attached Devices report on the router?
       What are the IP addresses of these devices?
       Does "ping" work from "the laptop" to the router and to the printer?
    • cleveland35's avatar
      cleveland35
      Router:
      Hardware Version           R7000P
      Firmware Version            V1.3.1.64_10.1.36
      Connected to a cable modem.
      No problems using the desktop or laptop when using an ethernet wired connection.
      Both running Win 10.
      Not using "guest" networks.
      Just trying to use Windows to add the printer.  Doing START and then type printer, then select Printers & Scanners and doing Add a Printer.
      The laptop that was wired saw the printer, allowed it to be added and could print.
      All devices appear in the router list.  The printer is 192.168.1.8
      Have a conflict but will try to ping the devices tomorrow.
      Thank you for the quick attention.
      • antinode's avatar
        antinode
        Guru
        > [...] will try to ping the devices tomorrow.
           Ok.  Could be educational.
           Another diagnostic would be to use a web browser to try to talk to
        the printer's "embedded web server (EWS)" at
        "http://<printer's_LAN_IP_address>".  "ping" uses an ICMP echo request,
        which is a low-level IP network thing.  Access to the EWS might more
        closely resemble normal printer (TCP/UDP) traffic, making that a more
        realistic test.
           Conceivably "ping" could work, but the firewall-like rules used for
        guest isolation, if misapplied (by lame firmware), might still block
        normal wired-wireless traffic.
           That looks a little stale.
        for Downloads.  (For older versions, under Firmware and Software
        Downloads, look for "View Previous Versions".)  Find the kit(s).
        Download the kit(s) you want.  Read the "Release Notes" file for
        instructions. (In the User Manual, look for "firmware", and, especially
        for a topic like "Manually Upload Firmware to the Router".)
