Chestersam
Nov 18, 2018Follower
D8500 - Bridge Mode option doesn't appear
Help please - D8500 Nighthawk AC5300 Wifi Modem Router
"use other operation mode" check box and enable bridge mode radio button are not showing in the Advanced>Advanced Setup>Wireless Settings menu. Can't locate in any other menu either - what I am missing?
Trying to use in bridge mode rather than AP
Latest firmware installed V1.0.3.42_1.0.1
Bridge mode can mean several things. Modem only mode to feed a router, wifi bridge to be a repeater. Which are you after?
There is a manual for the D8500 somewhere at the end of this link:
>>>> D8500 | Product | Support | NETGEAR <<<<
By the way, you have posted your message in the section of this community given over to
Nighthawk WiFi Routers
The D8500 is a DSL Modem/Router.You might get better replies, and find other answers, over in the appropriate section:
DSL Modems & Routers
1 Reply
