Dec 17, 2016Guru - Experienced User
Disable DNS Relay on R9000
Sorry if this question has been asked before. It's been a while since I had been using NG.
I was curious of DNS Relay could be disabled on the R9000 or if NG keeps this feature closed on there products?
Thank you.
Netgear does not offer the option to disable it. You can upvote my request here.
