JasonArbaugh
Aug 19, 2020Follower
Enabling RAX80 Link Aggregation Break WiFi
I recently upgraded the home network because I am WFH like most everyone else. After running ethernet through my attic (in Texas), dropping the cables through the walls, and configuring two new Netgear Switches (JGS524Ev2 and GS116Ev2), I decided to maximize the bandwidth from the wireless devices to the home network.
Tonight I created a LAN on the Netgear JGS524Ev2 24-port switch to connect to my Nighthawk RAX80 router. I then enabled the LAN function on the RAX80 ( Advanced > Advanced Setup > Ethernet Port Aggregation). I selected the "Static" option because the Netgear JGS524Ev2 24-port does not support LACP-IEEE802.3ad. I then let the RAX80 reboot with both ethernet cables attached and it looked like it worked...
Except the WiFi would no longer connect to any wireless device.
I tried Dell laptops, Apple laptops, iPhones, iPads, Apple TVs, Amazon Echos, Nintendo Switchs. Nothing!
After reflashing with all three posted Firmwares (1..46, 1.0.41, and 1.0.35) and trying many combinations, I finally reset the device to Factory Settings. And I suddenly noticed that my phone connected to the default NETGEAR wireless network. (Thank goodness it remembered the network from the original RAX80 install.) I reconfigured the networks and passwords, and all the devices started connecting. I then went and enabled port aggregation and EVERYTHING DIED again.
Has anyone had a similar problem?
Is the WiFI supposed to work with Link Aggregation enabled?
Is my router just defective and I only noticed it now that I went to enable the LAN feature?
Any assistance would be appreciated in understanding if I have busted hardware or if the features just do not work together. (They should work together, but as an engineer, I have to ask the question.)
- Christian_RNETGEAR Employee Retired
Hello JasonArbaugh,
Welcome to the community! I'd like for our support team to reach out for further investigation. If you wish to be contacted, please send me a private message with your email, phone, and serial number.
Thanks,
Christian
- hotwkeAspirantI am having the exact same problem! I have the Netgear CM1200 modem and the Netgear Nighthawk RAX80. I enabled the LACP-IEEE802.3ad on both, running LAN 1 to Port 4 and Lan 2 to Port 5 (running tested Cat7 cables). Says LAG is active... But still no WiFi. Does the WiFi on the RAX80 ONLY work with a connection to the WAN port?? Am I that dumb I'm not getting this? Do I hook Lan 3 on the CM1200 to the WAN on the AX80??? I've been messing with this for the entire night and I'm at my wit's end......
Thanks- schumakuGuru - Experienced User
hotwke Suspect you mix the LAN LAG with the Internet LAG config to conect a cable modem suppoting LAG.
Nighthawk AX8 User Manual p.87, "Get Multi-Gig Internet With Internet Port Aggregation"
"3. Connect the Internet port and Ethernet port 1 on your router to two Ethernet ports on your modem."
- hotwkeAspirantThank you!! Yes, I was mixing them!! Was so excited to try out the CM1200 and just.... You know. Haha *Smacks forehead*
