- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
HMAC Authentication Errors (via VPN)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings---
I have a Nighthawk X4 (R7500), and have enabled the VPN Service per this article:
https://kb.netgear.com/25389/Enabling-VPN-service-on-a-Nighthawk-router-using-a-MAC-OS-computer
Everything connects fine, but I get the following errors:
2018-04-09 12:59:54 Authenticate/Decrypt packet error: packet HMAC authentication failed
(repeated)...
I am able to access resources on my local network, but the connection is VERY slow.
Services like RDP are impossible to use.
My config:
client
dev tap
proto udp
sndbuf 393216
rcvbuf 393216
;dev-node NETGEAR-VPN
remote xxxx.xxxxx.net12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
;remote-cert-tls server
cipher AES-128-CBC
comp-lzo
verb 0
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I resolved this by switching to TCP Mode and redownloading the openvpn config.
The biggest differences were:
client
dev tap
proto tcp
sndbuf 0
rcvbuf 0
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: HMAC Authentication Errors (via VPN)
More info:
It looks like I get a connection and I am able to see UDP RW packets correctly.
I am able to connect to the router itself via http (e.g. 10.0.0.1), but it generates the HMAC authentication messages and moves VERY slowly.
I am able to connect to my local workstations via RDP, but it is very very slow.
For a test, I forwarded RDP ports and it moves very quickly/normally.
So it appears that there is something lost in the decryption? overhead?
- Mark as New
- Bookmark
- Subscribe
- Permalink
client
dev tap
proto tcp
sndbuf 0
rcvbuf 0
