Orbi WiFi 7 RBE973
Reply
How to configure two wireless Engenius EAP600 access points to a Netgear AC1750
bbqmanone
Hi,
I'm currenly running an Engenius EAP600 wireless access point which is connected to my Netgear AC1750 router. I would like to add a 2nd EAP600 access point in a different location of my house and not sure how to go about it. Is it as simple as assigning a new Ipaddress to the 2nd wireless Ap and configuire it with 2 new SSIDs. Any info would be greatly appreciated.
Thanks in advance
Mike Garofalo
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: How to configure two wireless Engenius EAP600 access points to a Netgear AC1750
Yes, you would connect it the same way as the first one and assign it a new Ip and SSID.
DarrenM
Message 2 of 3
All Replies
DarrenM
DarrenM
Message 2 of 3
bbqmanone
Thanks. Up and running.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1190 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
