Reply
Is 802.11 WPA2-PSK operating in AES or TKIP encryption
GigabyteGuy7491
Follower
Looking for AES Encryption in WPA2-PSK mode - does the R7450 model of the AC2600 Nighthawk operate with AES or the older TKIP encryption?
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 2
Accepted Solutions
schumaku
Guru
Re: Is 802.11 WPA2-PSK operating in AES or TKIP encryption
WPA2-AES is mandatory for 10+ years.
As per the nice documentation, R7450 User Manual p.66 you can select either WPA2-PSK [AES] only or WPA-PSK [TKIP] + WPA2-PSK [AES] for backward compatibility with legacy clients.
Message 2 of 2
All Replies
schumaku
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2249 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
