marshar's avatar
marshar
NETGEAR 21
Can someone please tell why I have "2" after my WiFi NETGEAR21? I am not able to access the internet as long as I use this router.
Thanks.
  • To signify its a 2.4Ghz SSID signal. You can change that to anything. You don't have to use that SSID name. Try something different.
  • FURRYe38's avatar
      • FURRYe38's avatar
        Be sure to mark your thread and solved so others will know.
        Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
        Enjoy.
