riaamp's avatar
riaamp
Netgear Modem and Nighthawk no internet connection
Slow internet on wifi yesterday.. freezes etc.  and now nothing. The modem works - I'm hard wired to write this. The Nighthawk has amber light on the interent connection. I've done everything I can find. Reboots, resets, changing cables... can't login to the router because it's not on the internet.. Nighthawk app on the iphone finds the router - tells me it's not connected to the internet! I know that.
I think it's dead. I'm very annoyed... Didn't buy it that long ago.
  • plemans's avatar
    1. what modem do you have?
    2. what firmware is on the router?
    3. did something happen to cause it? (storm, power surge, etc)
    4. what are the rest of the led's on the router doing? (color, blinking, solid, etc)
    • riaamp's avatar
      riaamp
      1. I have a netgear Voice Cable modem CM1150V.
      2. Don't know - can't get connected to the router
      3. Possibly - but not apparently. We've had a number of power outages due to storms. As I said initially, we had slow internet, and freezes (I was on Zoom) and then it stopped working entirely.
      4. LEDs All white: Power, 2.4 5.O  #2 port (i have a plug in it) and the wifi on and WPS button, only the internet LED is blinking amber. The others are off.
      Thanks for helping. I do think we have a sick router.
      • antinode's avatar
        antinode
        Guru
        > Model: R6700|Nighthawk AC1750 Smart WiFi Router
           R6700[v1], R6700v2, or R6700v3?  Look for "Model" on the product
        label.
        > [...] The Nighthawk has amber light on the interent connection. [...]
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual (at least).  Read.  Beyond the
        basic set-up instructions, look for the LED descriptions and
        "Troubleshoot".  Further reading might not hurt, either.
        > [...] can't login to the router [...]
           "can't" is not a useful problem description.  It does not say what
        you did. It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
        > [...] because it's not on the internet.. [...]
           Your router has its own little management web site, built in.  You
        don't need an Internet connection to talk to your own router.  Think
        about it.  If an Internet connection were needed to allow you to
        configure a router to get an Internet connection, then very few people
        would have an Internet connection.
