KenKul's avatar
KenKul
Tutor
Nov 16, 2016
Netgear Nighthawk R8000 VPN Pass-through
Hoping someone has a solution for me.
I have a R8000 netgear nighthawk X6 router at home. It works perfectly with all my devices except my laptop for work. There are times where I have to work from home, my laptop will connect to the router however it won't allow the VPN software to connect to my company's network. I have tried on several other routers and it works perfectly, just doesn't seem to want to work with my one.
I have tried all the port forwarding solutions I have found online and none seem to work. I work for a big company therefore cannot ask them to change any settings on their end due to security reasons. Is there a solution to this problem or is it a router fault? I'm hoping it's not a fault as the router was quite expensive, and I was advised that it should automatically allow VPN pass-through.
Any help/support would be greatly appreciated.
  • Hi KenKul,
    Try adding the IP address of the device where the VPN software is installed under the DMZ setting of the router. If still the same problem, try connecting the device directly to the modem and check if that works.
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi KenKul,
    JamesGL
    Community Team
  • Thanks for the response. Excuse my ignorance however I can't find 'DMZ setting' in the router settings. I have logged on and looked everywhere in the advance settings. Is there a certain area I should be looking for it in?
    When the device is plugged directly into the modem it works perfectly. However I can't sit where my modem is which is why I try to connect wireless.
    • JamesGL's avatar
      JamesGL
      Hi KenKul,
      You can see the DMZ under WAN Setup.
      JamesGL
      Community Team
    • JamesGL's avatar
      JamesGL
      Hi KenKul,
      You are welcome!
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      JamesGL
      Community Team
