Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk X4S AC2600 compatible with ADSL/VDSL
MrxAD81
Follower
Hello,
I own the NetGear Nighthawk X4S AC2600 Smart Router.
I wonder whether the router is suitable for support of "a
nnex-j" and "1TR112" standards for IP VDSL/ADSL via Deutsche Telekom (provider in Germany)?
Best regards.
Message 1 of 2
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Netgear Nighthawk X4S AC2600 compatible with ADSL/VDSL
Hi @MrxAD81
Welcome to the community!
You should be looking for an ADSL Modem Router. The one that you have which is R7800 is only a router.
You may check out the following models below:
Message 2 of 2
All Replies
ElaineM
Hi @MrxAD81
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2501 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
