Reply
NightHawk AC2300 no internet and no router connectivity
SpaceGoat
Follower
Nighthawk 3 month old, went to move the location of the router and modem, and now the router refuses the internet from the modem.  Modem is Spectrum ET2251 and when I hook up my Spectrum supplied router it works fine.  Downloaded the latest version of firmware and installed via routerlogin.net interface.  This had no effect on the router, still just a flashing internet light (amber).  power cycled many times, even hard reset.  Also started the system up in the correct sequece but still no joy.  Fortunely have the backup router but miss the range and feature or the 2300.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Guru
Re: NightHawk AC2300 no internet and no router connectivity
Did you power OFF both ISP Modem and router for 1 minute then back ON with the modem first then router?
Be sure your using good quality Lan cables. CAT6 is recommended.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 34 views
  • 0 kudos
  • 2 in conversation
Announcements
