broomington
May 30, 2022Aspirant
Nighthalk remote administration
Router R6700v3 firmware V1.0.4.122_10.0.95
The instructions to enable remote administration do not match the actual menu provided by the unit. There is a "always allow HTTPS access" but it does not enable remote management via WAN. How is remote admin enabled on this router?
There does not appear to be any other menu option to enable remote admin.
(I tried to request support but their support ticket website also appears to have problems).
Its not. Web page remote access from the WAN side was removed, you get some remote access and remote feature now with the Nighthawk app now.
That feature only setup HTTP(S) on the LAN side with using the routers web page.
- broomingtonAspirant
Thanks for the reply. This thing is junk then. I will be returning it.
The 6000 series is kind up in age. You'll be best to find something newer. RAX## something would be recommended.
OF course, if you need web page remote access, you'll need to probably find a different brand. NG has removed web page remote access from all of there router products.
Good Luck.
