gmpaixao's avatar
gmpaixao
Nighthawk R7000P not working after firmware upgrade to v1.3.1.44
Hi,
Yesterday night upgrade my Netgear Nighthawk R7000P (AC2300), using Admin page (192.168.1.1), after 30 minutes the amber light kept flashing, I went to sleep hoping the process will be finish during overnight, no success.
Here is my current situation:
- no wifi
- No Ethernet, after connect my computer I’m not getting an IP from the router. But the lights in the router seams “ok”
- Because the issue above I cannot ping 192.168.1.1
- In my last session in the admin page, shows full progress bar and the new firmware in the top left: v1.3.1.44_10.1.23
How can I fix this?
Thanks,
Gustavo
