shrinuvas
Aug 31, 2021Aspirant
Nighthawk X10 R9000 is stuck with 60Ghz after fw upgrade 1.5.0.36
@ links to members
My 2.4Ghz and 5Ghz stopped working after fw upgrade. I tried all sorts resetting to default and then fw upgrade downgrade. Turning wifi on /off but no luck. Any body experiened such problem. Need help stuck with this issue
turning wifi on/off but pushing and holding the button for 2 seconds? or by trying it in the gui?
- shrinuvasAspirant
I tried those option but hard pressing wifi on /off on router and then also doing via. GUI. something weird It just got stuck with 60Ghz. Currently setup i have spectrum cable modem connected over gig to this X10. It worked when internet was setup. but something weird happened after fw upgrade. I did factory reset. downgrade to .28 and then .26 and .24 and finally got back to same as .36. For now I got tired took away all the cables and power cord.
- shrinuvasAspirant
are there any known issues with these X10. Im losing trust with Netgear products.
