Orbi WiFi 7 RBE973
Reply
Nighthawk x6 ac2200 connecting issues to Nowtv hub 2
Tangoqueen
Initiate
just received and problems setting up. I'm using the nighthawk app but it won't verify my routers password. My router is Nowtv hub 2. Any suggestions. Thank you
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 4
Accepted Solutions
Guru
Re: Nighthawk x6 ac2200 connecting issues to Nowtv hub 2
have you tried installing using the installation assistant and not the app?
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 4
All Replies
Guru
Message 2 of 4
Tangoqueen
Initiate
Thank you so much, I think that's worked
Message 3 of 4
Guru
Glad it helped!
Let us know if you have futher issues
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 574 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
