Reply
Nighthawk x6s ac3000 (power adaptor available with AU plug?)
Robert888
Hoping someone can help?
I just purchased a Nighthawk x6s ac3000 Router from eBay from America still waiting for its arrival.
I have looked in the user manual to determine the power adaptor and determined it is 19v 3.16a and 50Hz. Instead of converting the US to AU power adaptor with a converter I was wondering if these power adaptors can be purchased with an AU plug?
I am struggling to find one on line but can find some laptop power adaptors with same output. Prefer to use original power adaptor. Is this a possibility if I am unable to get an AU power adaptor?
look forward to any feedback.
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Nighthawk x6s ac3000 (power adaptor available with AU plug?)
> I just purchased a Nighthawk x6s ac3000 Router [...]
   None of that is a model number.  Look for "Model" on the product
label.
   "R7900P" is a model number.  (Is it yours?)
> [...] determined it is 19v 3.16a and 50Hz. [...]
   Don't confuse input characteristics ("50Hz") with output
characteristics ("19V/3.16A").  The router cares only about the
asapter's output.
> [...] I was wondering if these power adaptors can be purchased with an
> AU plug? [...]
   Netgear buys them; Netgear doesn't make them.  You should be able to
buy one, too.  Netgear doesn't sell parts.
> [...] Prefer to use original power adaptor. [...]
   Define "original".  Same as Netgear buys?  ebay.com.au?
   I'd look for an adapter with the desired input characteristics and
connector, and the desired output characteristics and connector.
Seeking "original" might be a lost cause.
Message 2 of 2
All Replies
antinode
Guru
label.
asapter's output.
> AU plug? [...]
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 522 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
