Brooklynbl's avatar
Brooklynbl
Nighthawk x8 8500
The red light on this router won’t go out. I have changed cables, unplugged, reset, turned everything off then on. Ran troubleshooting in netgear app, said the router was working, its not. No matter what I do the red light wont go off. This all started after a Comcast outage last week. They said my modem is fine and the Comcast side is ok. This rout was very expensive and only about 3 years old. The cost to call support just to answer this question I can buy a new router. Help.
