jasonnewbery97's avatar
Jan 28, 2017
Old BT login details
I've just upgraded my router to Nighthawk R7000 from a Hub 5. All installed and working fine but when I look in my available WiFi list on my phone and PC I can still see that the old Hub 5 is still available to connect too. Any ideas why?
  • Not with same the same login details.
    I have worked it out now. One of my bt extenders had not reset properly and still thought it was part of old system.
    Thanks
    Thanks
