Reply
OpenVPN update breaks R7000 and probably other routers VPN implementation
chopin70
Virtuoso
Affected plateforms: Android
Spoiler
Change log that fixed the issue:
Changes from 1.1.23 to 1.1.24:
* relax the certificate validation in mbedTLS to allow certificates with broken date format to connect
* re-enabled deprecated and insecure md5 signature algorithm. Support for md5 will be officially DROPPED on Apr 31st 2018
The previous update broke OpenVPN ability to connect to R7000 VPN.
This last 1.1.24 update of OpenVPN made it again able to connect to R7000 VPN
I am worried about the md5 dropped warning on 31 april 2018.
Are we concerned and is Netgear aware of it so that we do not loose OpenVPN for months before it is fixed on routers ?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: OpenVPN update breaks R7000 and probably other routers VPN implementation
Hi chopin70,
NETGEAR is already aware of it. We will provide an update on this concern.
Message 2 of 5
All Replies
JamesGL
Master
Hi chopin70,
Message 2 of 5
JamesGL
Master
Hi chopin70,,
Engineering team is working on this but no ETA yet for the release.
Message 3 of 5
chopin70
Virtuoso
Thank you
As soon as we have it working before 31 april 2018, it is ok. So that OpenVPN is not broken
Message 4 of 5
MLOD
April 31st?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5371 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
