- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Power light blinking, cant reset, cant get support EX6250
- Mark as New
- Bookmark
- Subscribe
- Permalink
Power light is constantly blinking, noticed we dont get wifi where we need it anymore. Cant do a factory reset, I also cant log into the router even with the trouble shooting help. the night hawk app doesnt work either. Says cant connect to the internet but we definitely have it. I cant believe netgear dont offer any support. Getting really frustrated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Power light blinking, cant reset, cant get support EX6250
Is this a new device? (checking to see if you're within warranty or not)
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
