- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
(R6700v3) Capped at 200mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Any help is appreciated (not home atm)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Issue is now FIXED!
Steps used:
- Updated router to latest version
- Factory reset
- unplug router or power off using on/off button
- unplug modem and ethernet cable
- Power on modem while leaving ethernet cable unplugged
- wait for modem to FULLY power back on (For me lights had to be solid)
- Plug ethernet cable back in (And back into router if unlugged)
- Power on router
Previously, I had to "mac spoof" on my router to get connected to the internet(During Netgear genie). After doing this, the issue was gone and now my default gateway is "10.0.0.1" instead of the previous "192.168.1.1". My speed is now what is used to be before I got my own modem (600-700mbps).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: (R6700v3) Capped at 200mbps
In AP mode, you should be able to change the wireless settings.
What gateway is it connected to?
try installing version 1.0.3.66 of the firmware. Then do a factory reset and reinstall. If you're putting it in AP mode, you should be good. If you're running it in router mode (with gateway in modem only mode or the netgears IP address in the gateways' dmz), then make sure after the reset to leave qos, access control, traffic monitoring, and parental controls all disabled. Don't install from a backup configuration.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The CM700 is a modem only device. If the R6700v3 is directly connected to it, then it shouldn't be in AP mode. there needs to be something controlling dhcp/nat
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Issue is now FIXED!
Steps used:
- Factory reset
- Power on router
User | Count |
21 | |
12 | |
9 | |
8 | |
4 |
