Orbi WiFi 7 RBE973
Reply
R7000 Internet port no longer working
stereophonic
The Internet port on my R7000 Nighthawk seems to have stopped working. Whenever i plug a standard or patch cable from my router the R7000 displays no Ethernet cable is connected.
Router that used to work is Netgear N300
Other router i've tried is Netgear DG834G v3
Any help would be awesome.
Thanks
Al
Message 1 of 12
Accepted Solutions
Babylon5
NETGEAR Employee Retired
Re: R7000 Internet port no longer working
Right, well the information posted in that status window is the result of the Link Auto-negotiation process, which should work even if you were to connect the WAN port to something like a PC rather than a modem. If it’s showing Link Down then I suspect the R7000 is faulty. If you contact Tech Support they may be able to help or offer an RMA.
I suppose one remaining thing you could try if you’ve not done so already is a Factory Reset, you may want to save the router configuration to a file first if you do this.
Message 11 of 12
All Replies
Babylon5
What is it that you’re connecting the R7000 to? Does the R7000 indicator light at all? What firmware version are you running? If you connect a cable from the WAN (Internet) port of the R7000 to one of its own LAN ports do you still see the cable error message?
Message 2 of 12
stereophonic
I'm trying to connect it to my netgear N300 router (something i have done and was working well)
I'm not sure what you mean by  Does the R7000 indicator light at all?
It's running firmware version V1.0.4.30_1.1.67
I still see the error message when i run a cable from the Internet port to the routers own port.
Message 3 of 12
Babylon5
I’m not sure if the router has a dedicated indicator for the WAN (Internet) port, I’m at work and can’t easily check, but I’m not aware of a router that does not have such an indicator.
If you log into the router, and look at the Router Status – Show Statistics page then what do you see for the WAN port when a cable is connected?
Message 4 of 12
rpoffen
Virtuoso
Yes, the R7000 has an indicator for the internet port. It is off if there is no cable connected. Amber if there is a cable connected to something, and white if there is an internet connection, which probably means it successfully received an IP address.
You should also be able to view the status page from a computer connected via WiFi or cable.
Message 5 of 12
stereophonic
Log from the router when cable is plugged into internet port from LAN port on the same router.
[DHCP IP: (192.168.1.2)] to MAC address 90:F6:52:E5:96:51.
[WLAN access rejected: incorrect security] from MAC 90:F6:52:E5:96:51.
[Internet disconnected]
[Initialized, firmware version: V1.0.4.30_1.1.67]
Log from the router when cable is plugged into internet port from LAN port on the DIFFERENT router.
[Admin login] from source 192.168.1.2.
The internet light remains off at all times.
Thanks for everyones input thus far.
Message 6 of 12
Babylon5
Can you tell me what the Router Status – Show Statistics window has to say about the Internet port? This should normally tell you the Link Rate / Duplex which might help differentiate between a hardware issue (port H/W failed) and a functional issue (can’t obtain an IP address).
Message 7 of 12
stereophonic
Sure,
How to add a screen grab photo to my post? I'm using chrome and when i click the insert image button it asks for the source of the image but no box to select image from my pc
Message 8 of 12
Babylon5
If you’re looking at the pop up window I’m thinking off you should see something like 1000Mbps / Full for the WAN (Internet) port when it’s working OK, or possibly in this case something like ‘Not Connected’. I’m not sure that needs a screen grab and I’m at work so can’t easily check the steps you need to follow to upload an image.
Message 9 of 12
stereophonic
For the WAN port it reads as link down
Message 10 of 12
Babylon5
Message 11 of 12
stereophonic
Thanks for your help.
I've tried many a factory reset 🙂
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 17553 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
