ChrisEndo's avatar
ChrisEndo
Follower
Jul 02, 2017
R7000 Wifi Stopped working - already tried reset button
Everything was working fine for a year, but now wi-fi doesn't work. My Apple TV is wired to the router and the internet connection still works, but wi-fi doesn't work
I tried:
- Reset button - doesn't work
- This https://kb.netgear.com/24101/How-do-I-enable-or-disable-the-wireless-radios-on-my-Nighthawk-router but got an error page because I wasn't connected by wi-fi (catch 22)
How can I log into the router without wi-fi?
    With a wired PC.
    Are the wifi lights on on the router?
    Have you checked that the wifi switch is on?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    With a wired PC.
