t24grant's avatar
t24grant
R7000 globe icon Red
Greetings, I have a red light on the globe icon and all others are white. I did the reset on both. The xfinity modem works with my old netgear model R3400, so not sure what to do.
  • Resetting isn't enough. That doesn't actually probably do what might be needed.
    Suspect the Modem is looking for a SPECIFIC MAC address of the old router. Can't find it when you hook up the new R7000 so it doesn't supply the signal for the Internet. When you put the old router back in, it sees it as the correct MAC address and hence it works.
    What you need to do is POWER OFF both the Modem and Router. If the Modem should have a BATTERY in it, you need to remove it and wait a few minutes before reinserting it. Then POWER ON the Modem and wait for it to FULLY come up. Only then POWER ON the Router. That should fix the problem if it is on because the MAC address was in conflict.
    Doesn't, that ARE you using the same cable between the modem and BOTH routers when you connect each one (assuming you've connected the cable in the correct slot for the input signal)?
  • > [...] The xfinity modem works with my old netgear model R3400, so not
    > sure what to do.
       The non-psychics in your audience have no real idea how either the
    old router of the new router have been configured.
       I'm not a cable-modem expert, but I gather that these things can be
    sensitive to MAC addresses.  On an R7000, under ADVANCED > Setup >
    Internet Setup, there's a section called "Router MAC Address".  Knowing
    nothing about the R3400, I'd guess that there's something similar on
    that one, too.  If these are set dissimilarly, then that might be enough
    to cause the problem.
       I should think that someone at Comcast should be able to get you
    going pretty quickly.  They must deal with this stuff very frequently,
    and they should have a better idea what's not valid about what your new
    router is trying to do (because it's talking to them).
    • William10a's avatar
      William10a
      Master
      The wndr3400 is a 10/100mb lan port router with simpler settings then the R7000 other then their ssid and password they want to use and the wndr3400 did allow a person to set the log in username and password too be changed.
      The r7000 should but along ther same general lines to setup other some setting in different places to set up.
      May need to do a total network reboot to clear old settings and allow the devices work with the new router.
      • antinode's avatar
        antinode
        Guru
        > the R7000 [...]
           Perhaps, but according to the oldest manual I could find for a
        WNDR3400v1 (Figure 1-6, page 1-7 (= PDF 20)):
        http://www.downloads.netgear.com/files/GDC/WNDR3400V1/WNDR3400_UM_31AUG2010.pdf
        the Basic Settings page offers the same "Router MAC Address" choices as
        the R7000.  The explanation is in Table 1-1, page 1-9 (= PDF 22).
           Of course, knowing the actual model number for the old router might
        be more helpful than an unreliable approximation of it.
    • > Suspect the Modem is looking for a SPECIFIC MAC address of the old
      > router. [...]
         Knowing nothing, I'd guess that the cable modem doesn't care about
      the MAC address of the router, but the ISP may care about the MAC
      address reported by the modem, and, depending on how the modem is
      configured, that could be the MAC address of the router which is
      connected to it.
         With a description like "The xfinity modem", it's tough to do much
      research on the particular modem in use here.
      > What you need to do is [...]
         All the resetting of all the devices in the world won't help if the
      ISP wants to know the MAC address of the new router before letting it
      connect.  Again, Comcast has people on staff who do this stuff all day
      long, so they could probably help more than the people here who can't
      see what they can see.
         But, if I were desperate for fun, then I might configure the new
      router to use the same MAC address as the old router used, and see if
      that makes a difference.  (And then, if that didn't work, I'd call
      Comcast.)
      • t24grant's avatar
        t24grant
        Powered both down and followed your instructions, unit connected!! Thanks
