- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7450 BOOT PROBLEM
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7450 BOOT PROBLEM
hi so when i turn my router on it lights up the wifi button white for a couple of sec then goes off and power light stays amber any help would be awesome thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7450 BOOT PROBLEM
so only the power light is on?
Have you tried a factory reset? Push and hold reset for 7-15 seconds while powered on?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
hmmmm seams thats not working at all guess this router is done
- Mark as New
- Bookmark
- Subscribe
- Permalink
where does it fail and whats going on? Details are key in helping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine locked up after attempting to update firmware to the latest version ....90 through the app. Will not factory reset. Seems bricked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
try a different power adapter and see if that fixes it. Amber light might mean the power adapter is bad.
