Bambipower's avatar
Bambipower
R7500 v1 does it support mu-mimo?
Having the r700v1... niw  i notice in the controle panel i can enable mu-mimo.
Is this now working on the v1 ?  Is it safe to enable it?
  • JamesGL's avatar
    JamesGL
    Feb 27, 2018
    Hi Bambipower,
    We apologize for the confusion. R7500v1 does not support MU-MIMO. This will be corrected on upcoming firmware.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Bambipower,
    Can you provide the screenshot of the page that shows MU-MIMO feature that can be enabled?
