Orbi WiFi 7 RBE973
Reply
R7800 in AP mode- cannot access web console from another subnet
StaticFree
Tutor
I set up the R7800 router in Access Point (AP) mode and have given it a static ipaddress.  Also disabled DHCP.
It is connected to my network on a VLAN with subnet ipaddress 192.168.100.4.  From my private subnet with different ipaddresses in the 192.168.1.xxx range, trying to logon to the Netgear R7800 fails with the error message:
404 Not Found
This server does not support the operation requested by your client.
I've searched the internet for this problem and see it has been a problem with just about all Netgear devices firmwares for many years back and to this date nothing has been done to fix it.  It seems that in the Netgear firmwares they coded a module that will not allow a client (like a Windows 10 PC) with a different subnet ipaddress from the R7800 subnet ipaddress to access the web server GUI html.  Login when the Windows PC is on the same subnet ipaddress as the R7800 works fine.
I tried updating to the latest firmwares including Voxel's latest firmware R7800-V1.0.2.80.5SF and the problem still exists.
Is there anyone at Netgear that can finally escalate this issue and get it fixed?
Message 1 of 4
Re: R7800 in AP mode- cannot access web console from another subnet
Message 2 of 4
StaticFree
Tutor
Whether or not this issue is caused by disabled functions while in AP mode this is a bug that should be fixed by Netgear.  I can't believe they still have not addressed this issue.
Message 3 of 4
antinode
Guru
> a static ipaddress. [...]
   Ok.
> [...] Also disabled DHCP. [...]
   Pointless?  Selecting "AP Mode" should do that automatically.
> 404 Not Found
   What, exactly, is looking for what, exactly, (without success)?
> I've searched the internet for this problem and see [...]
   Thanks for the helpful links.
> get it fixed?
   I'd expect so, but an actual support case is more likely find its
way to any such person than a complaint here is.
   I don't generally deal with local VLANs, so I know nothing, and I
can't see what's actually happening in your case, but I wouldn't expect
LAN operations between different subnets to work without involving a
router.  Hence, it's not obvious to me that there's actually a problem
(with the router) to be "fixed".
> mode this is a bug that should be fixed by Netgear. [...]
   I doubt that the cause (bug or other) is a "disabled function"; more
likely, I'd say, it's some incompatibility between the expectations of
the relevant HTML and those of the user.
> [...] I can't believe they still have not addressed this issue.
   That's easy to explain.  How many users of this consumer-grade device
do you think might be affected by such a problem?  With the backlog of
more common bug-reports which Netgear must have, I'd be amazed if
anything like this ever bubbled to the surface.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 800 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
