Corregidor's avatar
Jun 12, 2016
R8000/R7900: No Wireless Bridge Mode?
Surprised to see that there is no bridge mode option in R7900/R8000 admin settings. The only feature that's available is the Wireless AP mode. Is this correct? Am I missing something?
Even on the R7000, there is an option under Advanced Setup > Wireless Settings to convert one of the radios to connect to another router (Use other operation mode > Setup Bridge Mode Wireless Settings). Is there any reason why this would be disabled on the R8000/R7900? Is there a firmware version that still has this feature enabled that I can revert to? I have the R7900 variant, and my current firmware is 1.0.1.4.
To clarify, I'm not talking about bridging an IPTV to the Internet or using the R8000/R7900 as an AP. I'm talking about getting the R8000/R7900 to wirelessly bridge with another wifi router.
    • TheEther's avatar
      TheEther
      Guru
      Yeah if you click on This answer applies to the following products you'll see that it doesn't apply to the R7900/R8000.  I can kinda understand why Netgear doesn't offer wireless bridging on these models.  It's a waste to use a tri-band router as a wireless bridge.  Only 1 Wi-Fi band can be used.
      • Corregidor's avatar
        Corregidor
        Tutor
        I actually think tri-bands are excellent as bridges. You use 1 5Ghz band to connect to the other router, and you still have two radios to repeat your own subnet. With the R7000, once you use up your 5Ghz radio, your local clients can only use 2.4Ghz.
        But shouldn't that be left up to the user? It doesn't make sense that a lower-powered router with less bands has more features.
        I might be encouraged by the "currently" in this response in their FAQ:
        Is the WDS/Repeater mode available on the R8000?
        Currently, the WDS/Repeater mode feature can only be supported without security. Therefore, we have removed this feature from the R8000.
        But this answer has been around for many years now, so it doesn't seem likely to change. If Netgear tracks feature requests, +1 from me for bridge mode on the R8000/R7900.
    • Carlangaman's avatar
      Carlangaman
      Initiate
      can you tell me what exact fw you used?  I have a second R8000 that I would like to use as a repeater but the DDWRT from Kong seems to have issues with this mode bricking it based on the myopenrouter website.
      • eljf's avatar
        eljf
        Tutor
        i tried to use dd-wrt, to make R8000 a range extender. But I can't find the settings that work in the WRT UI.
  • Just went to install a R9000 for a customer.  Put it in bridge mode, no AP mode, not Route mode.  Once in Bridge morde it wont broadcast any wireless even though there is a wireless setup link/page on the Bridge mode config page.  Any ideas?
    • TheEther's avatar
      TheEther
      Guru
      Bridge mode is used to connect wired clients to a Wi-Fi network.  The setup page is used to select the Wi-Fi network that the R9000 will join.  It will not broadcast its own Wi-Fi network.
    • victorwong168's avatar
      victorwong168
      Tutor
      Hi,, have you figure this issue? i am trying to tether my cell unlimited data to my router as my location's ADSL line sucks!  any thoughts?! thanks!
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi victorwong168,
        There is no issue with wireless bridge. I have provided the link on how wireless bridge works for home routers.
  • My R6300 would broadcast on both 5 and 2.4 in Bridge Mode. It was an easy way to link internet between routers while maintaining separate network authentication in separate rooms and avoiding the interference of repeaters. I upgraded to the R7000 and now Bridge mode less functional by literally only bridging wireless to wired devices.
