Hayashida's avatar
Aug 05, 2021
R8000 does not allow me to log on from routerlogin.net
I updated the firmware. I had to factory-reset because it broke configuration and WiFi does not work.
After factory-reset, the router does not allow me to access routerlogin.net. When I access it, it jumps to https://www.netgear.com/home/services/routerlogincom/
The page has a link to this page.
https://kb.netgear.com/27199/I-can-t-access-my-router-what-do-I-do
It says that I can access to the admin console from www.routerlogin.net or www.routerlogin.com, but they jump to https://www.netgear.com/home/services/routerlogincom/ again and I'm stuck.
Firmware version is not certain because I am not able to access the admin console.
  • Now I am trying to setup from a smartphone. The Nighthawk app requires me to scan a QR code but I lost the QR code.
      • antinode's avatar
        antinode
        Guru
        > Same thing with 192.168.1.1 and 192.168.0.1.
           _Both_ of them?
           Hmmm.  What's the IP address of your computer/device?  To what is the
        WAN/Internet port of the R8000 connected?  (Is it another router?)  What
        happens if you disconnect it?
           Have you tried a different web browser?
