- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 with unifi security gateway
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently bought the Unifi Security Gateway to provide a more indepth firewall element to my network. I currently run a cm1000 modem and a R8000 Nighthawk. I was finally able to power cycle the Unifi into submission and my internet is working through the home ports, however, I have no wifi coming from the Nighthawk.
I have it set up to go from Modem-to Unifi-to Nighthawk. The nighthawk is the pivot point to access the rest of the house and it's wired ports, and I am getting internet through it. Another odd portion is the Unifi Sec gateway is picking up the router, however, it's IP is now a 10.0.0.1.
To be honest I'm not sure what to do or how to get the wifi portion working on the nighthawk. I have not created any rules or firewall settings at all yet. I am open for suggestions.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Unifi gateway. If you put the r8000 in AP mode and connect it to the gateway things should work. Follow the manual for configuring the r8000 into AP mode. Also do any wifi configuration you need at that time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 with unifi security gateway
Any routing/NAT/port forwarding, DHCP, ... must be done on the security gateway. Re-configure the R8000 as a wireless access point -> https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-s...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
