seattleracer
Jul 18, 2016Follower
R8300 vs R8500
What's the difference between the R8300 and the R8500? Both seem to be Nighthawk X8 tri-band wifi routers. i'm asking to know if firmware updates for the R8500 will work for the R8300.
Hello seattleracer
Welcome to the community!
R8300 has only 1 USB port and its WiFi speed is 600 + 2166 + 2166 while the R8500 have 2 USB ports and its WiFi speed is 1000 + 2166 + 2166.
You may see more comparison here.
The firmware is not interchangeable.
1 Reply
- ElaineMNETGEAR Employee Retired
Hello seattleracer
