mak1965
Apr 25, 2018Follower
R9000 Extension Antenna
Hi,
I am wondering about using and extension antenna on my X10 Router. I had a Nighthawk 7000 and it was easy, I unscrewed the stock antenna, and screwed in an amplified antenna to that socket. Is this an option for the X10?
Thak You!
- William10aMaster
As far as I know the antennas are part ofthe router's body and also the output amps for the wifi, they are not able to be replaced by the normal user.
- johnson307Aspirant
Did you experience any signal loss with the amplified antenna you used? Which antenna did you end up going with? I'm trying to do something very similar, but I don't want to go to all the trouble only to have signal loss/drop. Thank you in advance!
As the one user already posted, the antennas are not removable or replaceable. So you can't change them out. The OP has not been online since they posted back in 2018.
- johnson307AspirantUnderstood and thank you for the prompt response. This is my first time ever posting an inquiry so I apologize if I missed the place to look where someone was last online. Regardless, the antenna on my router are in fact removable so I am a little confused about that part. Can you please elaborate? Thank you in advance!
- LewisstructureAspirantYes, can the NightHawk X10 R9000 Antennas’s be removed or use extender antennas to it?
If you don't see any kind of screw or finger/thumb turning ring on the end of the antenna closest to the router case, then no, you can't remove those.
