× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX15 AX1800 Internet speed only peaks at 300mbps
mpe2903
Hi,
I have a similar issue as described here:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX15-AX1800-bottlenecks-my-intern...
This did not solve my problem however.
  • I removed all the settings as described like QoS, etc
  • Factory Reset
  • Rolled back firmware and then restored the latest.
I have a gig connection but I can never get more than 300.  Right now i'm at 100.
I think at this point I was sold a lemon but i'm hoping theres a resolution that doesn't include me buying a new router.
Thanks.
Message 1 of 6
Guru
Re: RAX15 AX1800 Internet speed only peaks at 300mbps
You have an RAX15.
What firmware is on it?
What modem/gateway are you connected to?
How are you testing? Wired? wireless?
What website are you testing on?
Message 2 of 6
mpe2903
My Router: Nighthawk RAX15
Firmware Version V1.0.2.64_2.0.42
Arris SB8200 modem.  980mbps down direct connection.
wired and wireless with multiple devices
xfinity speed test, speedtest.net
Message 3 of 6
Guru
What port on the SB8200 are you connected to?
Make sure its port 1 and nothing else is in port 2.
have you tried a different cable between modem/router?
After you reset the RAX15, did you ever speedtest it with it running in default configuration? without changing anything in settings?
I'd try this.
Message 4 of 6
mpe2903
  • Port 1 on the SB8200
  • Swapped cables
  • Speedtest after factory reset
Same result
Message 5 of 6
Guru
I usually don't say this (and not sure if rax15 has this) but have you went into the dynamic qos and manually set your speed?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 982 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
