Klopez79's avatar
Klopez79
Rax200 range extender
I currently have the nighthawk RX 200 router and I'm looking to get a range extender. Which one is the best one? If I get a mesh satellite it has to be used with the mesh system router correct?
  • I'd recommend either the AX extender (EAX15, EAX20, EAX80) or one of the triband AC ones (EX7500, EX7700, EX8000).
    I've used the EX8000 with my RAX200 and it worked great.
  • plemans's avatar
