JGelon's avatar
JGelon
Reset port forwarding to release port 80
I was able to set port forwarding on my nighthawk. However I made the mistake of using port 80 and so I can't access the admin UI anymore. Is there a way to access it again, hopefully without resetting the entire router.
Is there maybe an API/SSH connection I can use to remove the port forwarding rules.
I hoped my Synology would have been able to, but unfortunately it won't let it as they have been added as custom forwarding rules.
  • JGelon's avatar
    JGelon
    Apr 09, 2020
    Apparently a reboot of the router already did the trick to revert the change of port 80.
  • > Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
       Is that accurate?  Firmware version?  Connected to what?
    > I was able to set port forwarding on my nighthawk. [...]
       Swell.  How, exactly, did you do that?  Why?  Actual port-forwarding
    rules?  Copy+paste is your friend.
    > [...] However I made the mistake of using port 80 and so I can't
    > access the admin UI anymore. [...]
       "using port 80" _how_, exactly?  Simply configuring a port-forwarding
    rule for an HTTP server (port 80) should have no effect on access to
    the management web site of the router.
       "can't" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] Is there a way to access it again, hopefully without resetting
    > the entire router.
       If you really did find a way to disable normal access to the
    management web site of the router, then a settings reset might be the
    only practical way to recover.  Saving a configuration file _before_
    making drastic changes can save considerable time and effort.
       Huh?  What, exactly, is your "my Synology"; what, exactly, did you
    expect it to be "able to"; and how, exactly, won't it let who/what do
    what, exactly?
    • JGelon's avatar
      JGelon
