Reply
Reset security questions
Cunli52
Follower
I am trying to access my netgear account in order to block certain websites however I'm not able to answer the two security questions. Where do I go from here? Thanks in advance.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 3
Accepted Solutions
Guru
Re: Reset security questions
The recovery questions are there if you've forgotten the password.
Problem is, if you didn't set them up (or don't know them) they still ask the questions but there isn't a correct answer.
If that's the case, you'd need to factory reset to get back to the defaults (and reinstall it)
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 3
All Replies
Guru
Message 2 of 3
And then, when you set the thing up again, try to remember the answers to the questions you provide.
Or you can see if it is possible to disable password recovery.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 386 views
  • 1 kudo
  • 3 in conversation
Announcements
