NewInnMan's avatar
NewInnMan
Router Losses Internet at Weekend, and SSID broadcast at other times
Three issues:
1. Wireless router disconnects from internet from time to time, but particularly frequently at the weekends ( 4 or more time per hour).  Had to reboot router 4 times on Sunday, 2 times on Saturday and Firday evening.
2. Wireless router losses SSID broadcast and wired ethernet connections when a Netgear WiFi extender is added wirelessly, or Nest Camera signals an event.
3. Wireless SSID is broadcast but wireless devices cannot connect because "password is incorrect", even though it is not and all devices were previously connected.
Tried so far.
1. Replaced old Netgear router with a brand new router two weeks ago (NightHawk D7000 v2).  All three problems persist.
2. Had BT perform line tests at the CO (or Telephone Exchange) and at the home.  No issues found on the line.
3. Had BT replace Master Socket.  Connecting Wireless Router directly to Master Socket via DSL filter.
4. Disabled 5GHz band, leaving only 2.4GHz open
5. Disconnected all devices from the router, including WiFi extenders, and then re-introduced a device everyday.
6. Set 2.4GHz SSID to channel 11
Set-Up:
x4 iPhones wireless
x2 XBOXOne wireless
x2 Alexa Dots wireless
x1 iPad wireless
x2 Laptops wireless
x2 Sky STB's Wireless
x2 TV's Wireless
x3 Apple TV's wireless
x1 iMac wireless
x1 Nest Cam wireless
x1 Nest Thermostat wireless
x2 Smart TV's wireless
x1 Philips Hue Bridge wired
x2 Dyson Cooling Towers wireless
x1 Wemo Plug wireless
x1 no clue what is going on!!! All help appreciated
  • Solved this problem with the help of the Netgear Team.
    1.  Full factory reset.   This seemed to stop the drop out of the SSID broadcast.  But the internet connection kept droppiing intermittently.  The Internet light on the router flashed orange/white/orange/white on and on.  This seuqence isn't shown in the user manual.
    So,
    2.  We increased the MTU value to 1500.  www.routerlogin.net > Advanced > Set Up > WAN Set Up > "MTU Size (in Bytes)" > Enter: 1500
    48 hours later, and over the weekend, we have an un-interrupted service.
  • I think you're choking the router with all the wifi devices you connect at once. If possible, move stationary devices like TVs/BD players to wired connections
    • NewInnMan's avatar
      NewInnMan
      I have also thought that, but ruled it out.
      1.  Forgot to mention that with the old router, I had 4 of those devices wired via RJ45 rather than wireless, and still had the same issues.
      2. The instruction manual says that this router can handle 136 clients, 68 per SSID.  Not connecting near this number.
      3. Not all of the devices are turned on / in the house / or streaming data at the same time.  I would estiamte that between 6 and 10 are pulling user demanded data.
      4.  Even if I have 6 devices connected to the D7000, and have some of the others off-loaded to the WiFi extender, I have the problem that the SSID braodcasts shut down.  I would not expect that configuration to bring down a $200 router.
    So,
