Orbi WiFi 7 RBE973
Reply
Slow Ethernet Speed on Nighthawk X6S R8000P (cable works ok, wifi works ok)
generationbk
As the title says.
I just replaced my standard Verizion router with a new NetGear Nighthawk router.
With the Verizon router, ethernet speed was great. Now it's barely hitting 5.49 Mbps download when I try to do the speed test. I tried the ethernet cable with another computer and the speed works ok. So it seems like it's an issue with my computer specifically. I tried almost all of the solutions in the other threads but because those are a few years old, I wanted to revisit this.
Firmware version - V1.4.1.50_1.3.10
Things I have tried
- Reset of the Router
- Uninstalling NetWork adapters then reinstalling by searching for new hardware
- Most up to date drivers as per Windows
- Turning IPV6 on/off
- Turning QoS on/off (WMM is enabled right now)
Just a little confused because the ethernet speed worked great before and all I did was change the router so not sure where the issue is.
Thanks,
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 3
Accepted Solutions
generationbk
Re: Slow Ethernet Speed on Nighthawk X6S R8000P (cable works ok, wifi works ok)
Hi,
Thanks for reaching out.
I ended up finding the solution by disabling the xFast LAN program that was automatically downloaded with my Asrock Motherboard. That upped my speed by ~10x, so it's all fixed.
Just to answer your question, I am using Fios.
Take care.
Message 3 of 3
All Replies
Guru
What is the router connect to? What device?
Are you using verizon fios?
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
Message 2 of 3
generationbk
Hi,
Take care.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1077 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
