Orbi WiFi 7 RBE973
Reply
Telnet on R7000?
CrimpOn
Guru
Telnet on R7000?
Sorry if "this horse died a long time ago".  After much searching, I am unable to determine that telnet can or cannot be enabled on the Nighthawk R7000, firmware 1.0.9.88_10.2.88 (current).
I located telnetenable2, which claims to work with R7000.  The Windows version aborts with "Password too long."  The Linux version runs, but the R7000 does not respond to telnet.
Thanks
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 8
Accepted Solutions
antinode
Guru
Re: Telnet on R7000?
> [...] I had not realized that UDP would return an ACK. [...]
   UDP itself doesn't, but the program which listens for the special
Telnet-enable message (Looks like "telnetDBGD" on my D7000) seems to.
(I didn't see it documented anywhere, but when I ran the experiment, I
detected a response when the request succeeded.
> [...] NTE does not attempt to open a telnet session, [...]
   That's not its job.  All it does is send the Telnet-enable message.
If that works, then the router firmware should enable/run its Telnet
daemon ("/sbin/telnetd").  Then, a normal Telnet client will have
something with which to talk.
> My conclusion (so far), is the current R7000 firmware isn't running
> telnet, or at least isn't listening on port 23. [...]
   Right.  A "connection refused" complaint from a Telnet client which
tries to connect to it would be another clue.  By default, the router's
Telnet server is disabled, but these Telnet-enable programs are supposed
to send the magic Telnet-enable message which should persuade the router
to enable its Telnet server.  And that's what's not happening.
> [...] Not answering SSH, either.
   I've never heard of a Netgear router allowing an SSH connection.
> [...] Do I need to scan all possible ports, and maybe Netgear put
> telnet or ssh somewhere else?
   I doubt that that would help.  Many things are possible, but I
haven't seen any evidence that Netgear uses any odd-ball ports for this
stuff.
   Around here, on a handy D7000 (vaguely similar to an R7000), for
example:
# ps | grep -i telnet
  781 root         0 SW   [ telnetDBGD ]
  782 root         0 SW   [ acktelnetDBGD ]
 2178 root       616 S    telnetenabled 10.0.0.1 506A03E9AE88 admin password
25785 root      1144 S    /sbin/telnetd
27377 root      1140 S    grep -i telnet
   I know nothing, but I'd guess that the "telnetDBGD"+"acktelnetDBGD"
pair are what handle the Telnet-enable message (and the response to
it?), and "telnetenabled" is what actually enabled the Telnet daemon
("/sbin/telnetd").
   As for receptive ports:
# netstat -an | grep ' LISTEN '
tcp        0      0 0.0.0.0:33344           0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:14369         0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:20005           0.0.0.0:*               LISTEN
tcp        0      0 10.0.0.1:1990           0.0.0.0:*               LISTEN
tcp        0      0 10.0.0.1:53             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN
tcp        0      0 :::80                   :::*                    LISTEN
tcp        0      0 :::23                   :::*                    LISTEN
   All of which, although potentially interesting, tells us nothing
about why this stuff stopped working when it did, or whether that
change was intentional, or just another recently introduced bug.
> [...] my hope is that someone on the forum has the expertise to put me
> out of my misery.
   Sadly, loading older firmware may be all that I can suggest.
Waiting for a useful response from Netgear to complaints here about an
unsupported feature doesn't seem to have been very productive so far.
Message 4 of 8
All Replies
antinode
Guru
> After much searching, [...]
   Where?
> [...] I am unable to determine that telnet can or cannot be enabled on
   All the evidence which I've seen suggests that Netgear broke it a
while ago.  See, for example:
      https://community.netgear.com/t5/x/x/m-p/1786837
> [...] The Windows version aborts with "Password too long." [...]
   How long is it?  I believe that the limit in these programs is 32
characters.
> [...] The Linux version runs, but the R7000 does not respond to
> telnet.
   An advantage of my NTE program is that it listens for a response from
the target device, and thus is better able to distinguish success from
failure.  (But I'll admit that knowing immediately that it failed is not
vastly superior to discovering later that it failed.)
Message 2 of 8
CrimpOn
Guru
THANK YOU for commenting.  I have searched Google, Netgear, user forums, OpenWRT, etc. and everything points to:
  • A "debug" option which no longer exists
  • A "debug" option which existed, but was commented out. (no longer exists, even as a comment)
  • Telnetenable, for Linux and for Windows 10
  • Your NTE program (thanks for the link)
I just installed NTE and got "No ACK message received".  I had not realized that UDP would return an ACK.  Wireshark clearly shows NTE sending the one UDP packetd. Then, my computer ARP's "who has this IP".  The R7000 answers, "IP is at my MAC".  And, that's it.  NTE does not attempt to open a telnet session, so I guess it was expecting an ACK because of the UDP packet and aborted.
My conclusion (so far), is the current R7000 firmware isn't running telnet, or at least isn't listening on port 23.  Not answering SSH, either.
Oh, geez.  Do I need to scan all possible ports, and maybe Netgear put telnet or ssh somewhere else?
Thank you, again.  Floundering for a couple of hours is really frustrating and my hope is that someone on the forum has the expertise to put me out of my misery.
Message 3 of 8
antinode
Guru
stuff.
example:
("/sbin/telnetd").
> out of my misery.
Message 4 of 8
CrimpOn
Guru
Thank you again for being patient with me.  I did scan TCP through 64000 and a few TCP ports are open, but none respond to telnet.
I knew SSH was far fetched.  It's the default on all my Linux machines, but no go here.
I just hope that Netgear doesn't turn off telnet on my Orbi.  There are a host of useful things that telnet makes possible on the Orbi.
As for my R7000.  "Oh, well."
Message 5 of 8
http://routerlogin.com/debug.htm
Message 6 of 8
CrimpOn
Guru
Sorry, not there on my Nighthawk R7000.
Message 7 of 8
antinode
Guru
   On mine, with V1.0.9.60_10.2.60, the page ("debug.htm") is there, but
I see nothing about Telnet on it.
   After reverting to V1.0.9.42_10.2.44, "debug.htm" mentions Telnet,
but only in code which was commented out.  (But a Telnet-enable program
like NTE still worked with that version.)
   More examples of "continuous improvement", Netgear style.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 7619 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
