Orbi WiFi 7 RBE973
Reply
Using R7000 with C7000
Jrut007
Follower
So I'm looking to do software updates and use the nighthawk app, but everytime I use the app I get an error saying can not find router even though I am connection to the router in my home with the C7000 internet turn off because I just use it as a modem because the c7000 is out of date and is unable to be used with the app. How do I fix this
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0, C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
antinode
Guru
Re: Using R7000 with C7000
   C7000[v1] or C7000v2?  Look for "Model" on the product label.
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 [...]
   Nothing to do with anything?
> [...] I'm looking to do software updates [...]
   Of what?  You can't change the C7000[vX] firmware.
      https://kb.netgear.com/000036375
> [...] everytime I use the app I get an error [...]
   Forget the app, and use a web browser?
> [...] I am connection to the router in my home with the C7000 internet
> turn off because I just use it as a modem [...]
   What, exactly, did you do to the C7000?  Disable its router, or
disable its radios, or what?
   Visit http://netgear.com/support , put in your cable modem+router
model number, and look for Documentation.  Get the User Manual (at
least).  Read.  Look for "Cable Your Modem Router to a Router and Use
Bridge Mode" and "Control the Wireless Radios".  Which did you do?
Further reading might not hurt, either.
> [...] How do I fix this
   I'm not yet sure what "this" is.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 337 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
