Orbi WiFi 7 RBE973
Reply
VPN on R7800
Hans-Brinker
VPN on R7800
I would like to install VPN on my R7800 router to protect all gadgets in my network when they access the internet.
Therefore I have the following questions:
  1. Does this modem have a VPN built in?
  2. What sofware does my modem need to accommodate VPN software?
  3. The vendor of my VPN software advises me to install Tomato as Firmware first. I just learned that the R7800 is not compatible with Tomato. As I understand Tomato is a software enabling the user to tweak the VPN in an easy way. Is ther any other programm that does the same and can be installed?
  4. I intend to use VyprVPN. Anyone have this installed and working on this router?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 6
Accepted Solutions
avtella
Prodigy
Re: VPN on R7800
LEDE (OpenWRT) supports using the router as a VPN Client.
You can try Cezary's LEDE builds:
http://dl.eko.one.pl/luci/lede/17.01-SNAPSHOT/targets/ipq806x/generic/
Message 4 of 6
All Replies
Hans-Brinker
Re: VPN on R7800
I understood from VyprVPN that they have no other way to get their application working on this router. So my next question is:
Is there any other VPN sevice that can be succesful installed on my router?
Message 2 of 6
TheEther
Guru
Re: VPN on R7800
Just to be clear, the R7800 is a router, as you stated in your first sentence.  It's not a modem, as you state in most of your questions.
The R7800 only has inbound VPN support.  There is no outbound VPN support on stock firmware.  You will need to use third-party firmware, like DD-WRT or OpenWRT.  I don't have a R7800, so caveat emptor.
Message 3 of 6
avtella
Prodigy
Re: VPN on R7800
Message 4 of 6
Hans-Brinker
Re: VPN on R7800
Thank you. I will have a look into it.
Message 5 of 6
mondenath
Prodigy
Re: VPN on R7800
No you can try the Voxel fw look  in the SNB forum .
He added the vpn client feature. Just need a pendrive for the config.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 10313 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
